Hello all,
I am attempting to revive a Massey 65 Diesel that died and would not restart. I found the the owner had not done anything with the fuel filters or sediment bowl in decades. After cleaning and inspecting and replacing the fuel filters, I primed the low pressure side of the system until I had flow at the injector pump and then eventually got it to fire off and run after bleeding the lines to the injectors.
It does not respond to throttle input though. The only way I can get it to start is to move the shutoff valve back and forth and then set it for full throttle. It will then start and rev up, run fine for a few seconds, but then the RPMs will drop and it will settle into probably 1500RPM. Movement of the throttle lever between full and half does nothing, and movement below half will cause it to idle down and die. Restarting in full throttle will help it regain RPM but again it will not hold. Occasionally it won't restart at all, and moving the shutoff valve back and forth several times seem to do the trick.
I have checked the linkage at the pump, everything seems intact. There are no external leaks in the fuel system anywhere. Flow from the lift pump seems good.
I'm not an experienced diesel mechanic, but what I thinking based on the state of the fuel system (see pics) when I replaced filters and the fact that a restart and messing with the shutoff valve helps is that I have a stuck metering valve or governor in the pump. High hour machine with little to no maintenance.
Do you all agree or is there something I should be doing before I dive into the pump. If it is the injector pump, is a reseal kit the way to go, or should I just bite the bullet any assume internal wear and purchase a rebuilt unit?
I run an outdoor power equipment repair shop, but most of my experience is with gas engines, which is why I'm reaching out here.
[/img:e0d74eb56b]
[/img:e0d74eb56b]
