Trying to learn more about making a multipower operate the same as a standard 6 speed. The main goal here is to make sure it has engine braking and the normal travel speeds as the high side is too fast for steep ground. On a MF 135/150 Could anyone explain a little more about locking out the Multi power? I am trying to figure out how to lock one in the low side. Do you use a spacer or weld gears together? If a spacer is used, do the gears have a little play? Did you also remove the secondary MP pump and linkage?
With this done to make it full time low, is the speed the same as other 6 speed MF perkins tractors y'all have used?
Many thanks.
Many thanks.
