I know how hard it is to troubleshoot intermittent problems and that I need to take a methodical approach, and have been trying to doing so... but... no luck yet and I thought it was possible wiser folks than me may have some pointers I can use. (It is too dark and cold to mess with it tonight...)
This is a MF 240 Diesel, made in the UK. I have two wiring diagrams and neither quite matches the tractor. I am the second owner and have had it for 25 years. It was very low hours when I got it and I doubt it was much modified.
The problem: Turn the ignition key and nothing happens... OR it makes a loud click and then nothing happens. It will go weeks between doing this. I'll try a bunch of different things and it will work fine for a few weeks, I'll think I fixed it, and then the problem returns.
One notable symptom is that in the loud click version ALL power to the tractor stops working for a period of time. If I disconnect the battery, let it sit for a few minutes, hook it back up, the lights etc. work. Hit the key to start and they all go out and won't come back until I've done the disconnect and wait thing again.
I've replaced the starter (with solenoid) probably unnecessarily. I've replaced all three fuses. At one point I thought I'd isolated the problem to the fuel gauge, but no...
At times the battery will read about 13 volts when not connected, but 7 when connected.
My thinking is that either there is a short somewhere (maybe more than one) or there is a relay I don't know about which needs to be replaced.
Any suggestions will be very much appreciated.
