I took old starter of and bendix area was covered in oil. I put on new starter and it had drain hole in the bottom and watery oil dripped out when running. It seems as if the old starter had no drain hole, and the watery oil accumulated over I'd say a few years. I took the plate off of the bottom of the bell housing and everything in the cavity drained out. The problem may be solved, my old fords have a drain hole in the bottom of the bell housing with cotter pin in it to rattle around and keep it from plugging I see no such feature on the MF am I correct or missing something? ( first old MF I've worked on) any thoughts on the oil accumulation or would it be somewhat normal, if only it could escape?
