Coyote Green
I just go this Mobility Big Dipper Loader for only $700 the guy i got it from said it needed the carb cleaned. I got it started but it only ran for a few seconds and then quit. I got it home, cleaned the carb and now it runs great.
I haven't had any problems yet. It holds great oil presser and doesn't smoke at all.
The little thing lifts over 2000lbs. I would like to get AG tires on it because it doesn't have any traction with the pickup tires.
But it does have NEW rear tires and one completely rebuilt tilt cylinder.
One thing that i didn't like was the gas tank was under the hood.
It made it impossible to put gas in it and if any gas was dumped it went down on the exhaust manifold.
I ended up putting the gas tank under the seat, there was plenty of room because under the seat was a weight box that was full of sand. It was also full of water due to lack of drain hole and it was starting to rust bad.
I got everything cleaned out and the gas tank installed. It's a lot easier to fill and a lot safer.
I am also going to inclose the cap for the winter, but that's another post.
Has anyone ever had experience with one of these?
