New Holland TL 90 pto problem
jhwis
New to me 2004 NH TL 90 tractor with loader with only 900 hours. PTO will stop under load, but not always. Was hauling manure and did a couple loads then it stopped mid-load. Took off spreader an it worked. It has the electric over hydraulic pull/push knob to engage. I wouldn't think it's an internal PTO clutch issue as previous owner didn't use PTO much at all. Is it the switch or solenoid issue? Any thoughts on where to start?
I would look up the relay and try replacing it. My 8240 had a yellow cube relay in the fuse panel that I had to replace.
