Mnethercutt
Howdy folks, got several different questions regarding my new-to-me JD-A and B that I'm gonna post in one thread so feel free to address one or all of these questions if you have thoughts.
Background: Purchased 3 tractors as a lot deal, a 1948 Farmall H, 49 B, and 50 A. None of them ran, and from what the previous owner (who had inherited them after the original owner passed) told me, the B had ran "several years" ago and he had no idea when the last time the A ran. After getting them trailered and back home I've spent the last few weeks working to at least get them running to identify if they're worth trying to repair now and get puttering around the yard, or hold on to them till I'm in a position to fully tear them down and do an end-to-end restore. I've got a few issues I'm looking for advice on before moving forward.
On the A:
On the A:
- The motor is locked solid. I've filled the cylinders with a mix of ATF and Marvel Mystery Oil and poured diesel in the crankcase. After a month of sitting I've got it where the crank and bearings have broke loose but the cylinders are still stuck. I pulled the crankcase access cover and can see movement in the crankshaft when I try and turn the flywheel by hand. The good news is that I borescoped both cylinders and while they have a fair bit of 'gunk' in them, the cylinder walls look decent and have minimal rust. What I'd like to try is hooking up my air compressor to one of the cylinders that has both valves closed and pumping air slowly into the cylinder to break the piston loose. My thought is that it would act almost like a power stroke and help get things moving. Is this a terrible idea? What other options are there that y'all have tried? To be clear I'm not about to dump 100PSI into the cylinder. I'm thinking slowly going up to something like 40PSI and seeing if that would work. The tractor does not have front tires on it so pulling it to break it loose is not a viable option.
- Like the A, the motor was locked up but came loose almost immediately with a little pressure on the belt pulley. Unfortunately the valves did not cooperate and after several attempts to free them I was forced to pull the head and remove them. I've got them cleaned up and am getting ready to reinstall both the head and the valves after a good cleaning and lapping, but am looking for general tips and tricks for success. This is my first time working on a horizontal shaft engine so the process is different than what I'm used to.
- As you would expect, the studs and nuts for the manifold were...uncooperative. All 4 nuts immediately snapped off. I got the manifold off but now I need to replace the studs. I tried to get 2 of them out by soaking them down with PB blaster for a few weeks then welding a nut onto the stud....and they broke off at the base of the head. So I'm sure I'll have to drill those 2 out. The other 2 have also been soaked but I held off on the nut welding trick since it went so poorly. Any advice on getting those out or am I looking at drilling and possibly tapping?
- Can I replace the manifold studs with grade 8 bolts? I'm sure Deere had a reason for using studs, but it seems like a much simpler design to just use a strong bolt (and a copious amount of anti-seize on the threads) to make things easier. Anybody done this?
