Janicholson
Good find. The pits on the splines will not bother action unless they are so severe they snag the discs. The discs travel less than .020 in use.
The best advice I can give includes 2 things: The ramps where the balls reside must be smooth on their bottom trough. dips or lumps will cause locking and un even application. Before putting the components on the tractor, lay the housing face up on some blocking so it is steady (the little cap sticks out). Put a new disc into the housing and center it. Place the assembled expander in place where it should be (linkage pointing to the rod hole). place the last disc on this, centering it on the expander. now use a straight edge across the housing over the assembly and use a feeler gauge (multiple blades are needed) to measure the gap. The housing wears, as do the expander surfaces, and the pinion carrier flange on the tractor. You are measuring the this wear, plus the running free space when the brakes are not applied. The gap should be between .035 and .050 inches. If more, the action of the brakes will be compromised and likely unreliable. The fix is to have the housing milled down the amount needed to get into this range. Putting money into this for new discs and the time/effort involved, is worth making them act like new, not being disappointed. These seem simple and easily understood. They are not the best brakes in the industry, and require cleaning and a look/see every year if used as a main tractor, or at least thought of as they start to get grabby or weak. Jim
