I have an older Hobart Hood and the auto darkening lens stopped working. I purchased a replacement lens from Amazon, but it doesn't seem to work correctly. Tried to buy a better one but I can't seem to get it to work. It has a disc type battery in it and has a grind feature and is adjustable from 6-13. Out of the package as soon as you turn from grind to weld the lens goes dark. It has a battery check button which when pressed does nothing. When turning it on battery light comes on and then goes off. Pulled battery and it checks good, changed battery same results. I left it out in the sun for 2 days and it would work if you turned the delay knob but even after welding a little it would go back to dark all of the time. No problem returning it if I want unless someone has a suggestion that's what I'll do.
Anyone buy a replacement lens that they are very satisfied with? I bought a Harbor Freight helmet to use but I'd really like my old Hobart working again. If not I guess I'm going to buy a new helmet. I just hobby weld but do want to protect my eyes and the older I get the harder it is to see anything! Open for suggestions. Really didn't want to spend $300+ for a helmet.
