Northeast Puller
I went to a benefit pull 6 year old boy with cancer.I thought I had this problem fixed but know way.My 1949 JD G when on a hard pull or up steep hill will skip a beat or 2.It is mostly stock with cast piston in it at 65 and 68 cranking PSI hot wide open throttle. Has good fuel flow. Dry air cleaner and have removed 50 years of junk from the air stack and carb pipe I have put the electronic ignition .coil and wires from CBS performance that did not help the problem . I have Autowlight 388 in it gaped at 35 or 40 thousands and and have tried both gaps.I have had the big nut carb off and cleaned using the drill bits and replaced the out of round venturi and put all new gaskets and plugs and new load needle's in it. The did not help . I ran it with better then 3/4 tank of gas for the heck of it and that did not help.The plugs burn a gray whitish color. First pull it missed under heavy load. I open the load screw up 2 clicks on the next pull and it missed even more. The load screw is set at 1 and 1/4 turns out as the book and Roberts carb said. So what rock have I not turned over on this problem?I am getting stumped and frustrated at this problem. I have even advanced the timing some and that gave me some more power but did not fix my problem either. Thanks for any help with this. If I could find a dynow and work the snot out of it maybe I could get to the bottom of this but just trying things at the next pull over the last 2 years is not getting it dun.
