Hi all. I fixed my previous tranny shift rail leak with a 3/4 Welch plug. Ran the tractor and found oil leaking from the sherman shift rail directly below it. I have another cover that I believe is the "new" style that has longer rail slides that get capped with Welch plugs. Questions....#1 has anyone been able to remove the top cover through the steering box hole? #2 what should I do with the open hole on top of the new cover? Tap it and put in a plug? #3 does that top cover need a paper gasket for spacing or could I seal it with anaerobic sealer? I glued the new 1 when I rebuilt the tranny and expect it will tear when removed. #4 any thoughts on why It would have started to leak or how to stop it before i take it back apart ? No noticable leak before I rebuilt. Cleaned the parts gently and reassembled. I did have a new detent sliding pin made, maybe that pin has scraped the shaft? Tractor is on jack stands and only has ran about 6 hours sitting in the garage partially assembled from a whole machine rebuild. I put 5 gal in the tranny and the oil level is below the bottom bolt hole and the full mark on the dipstick. Pics of the leak using a blacklight
