mike1972chev
Well ,This MIGHT be a bit of a loaded question, but I thought I would ask the more experienced than myself...
I am getting ready to change out my rear tires and tubes finally on my 1953 Super M stage 2. I have been debating whether or not to go ahead and take a look into the outer axle bearings and seals while I have it up in the air with the wheels off of it or not??? The tractor seems to have been LOWER hours when I bought it back in 2000 and the previous owner before me just kept it in the shed with his other adult toys and never really did anything with it. Clutch and brake pedal pad , cross hatch treads look like they are NOT very worn. I know, this is a SORT of way of judging hours on a tractor. Engine has had ONE ,VERY WELL DONE rebuild, and runs perfectly ! When I got it home, I drained the 90 WT out of the rear end and pulled PTO to look inside, all looked GREAT. I flushed the rear end out CLEAN and added the almost 15 gallons of gear grease. I have used it a few time a year now ever since...
The gear box and rear end still sounds fine. The axles show NO signs the bearings WOULD be going bad. ZERO signs of axle making it's way up into the outer bearing retainers or any signs of the outer axle seals leaking period. (I also always worry about the INNER bearing at the bull gears coming apart and getting in between the gears and the rear housing and busting them open like I have seen several times.)
To end up here,ALL seems well right now, but we are also talking about a 70 year old piece of machinery also !!! What should I be doing to make sure she can go another 70+ years along with myself ??? Thoughts,opinions??
