Golden T Farms
Hello All,
Early this spring, I inherited a 1954 John Deere 70 from my father-in-law. Since then, I've had several opportunities to run it for field work and general farm work on my brother's farm. After an oil change and new plugs and wires, the tractor runs well. However, recently, after dragging a 12ft disk around a field for about 3 hours, the temp started to go up, to the point of the antifreeze expanding and running some out the overflow. At 195 degrees on the gauge, I shut the tractor down. Since then, I've flushed the radiator and confirmed that the radiator itself is clear of debris. Before I fill the system back up with coolant, I was going to replace the thermostat as well. This is where I'm getting tripped up. I am a "YouTube Certified" mechanic, so my mechanical knowledge and skills leave something to be desired. The coolant return line/pipe coming out of the block of the engine is not like any others I see online. Neither is it like anything I can find in any JD documentation or manuals. There is a "port" where I would expect the thermostat to be, but when I take it apart, it does not look like any thermostat I have ever seen. See the attached photos. Have any of you seen this port on a 70 and Is this the thermostat or will I find the thermostat deeper in the port? Thank you for any advice, guidance and wisdom you can share!
