down_right
Farmall wiring diagram & new switch panelWiring diagram referenced in the post --->
So i am trying to rerun wire to restore the wiring harness, maybe using the oem lighting switch, or alternatively the rocket switch dock shown in the above photos.
I am somewhat confused in the wiring diagram as to what the "breakaway connector socket" (look at #8 on fender diagram) does. It looks as though its just a hub for connecting two sides (right/left) of a certain set of lights (headlights/floodlights/etc) from where a single wire then goes to the lighting switch to control both the right and left sides of the flood or headlights. so if I understand correctly it has the same function as basically using a wirenut to tie 2 lights together with a jumper wire which is then connected to the wire which is then switched hot/off?
Im asking because i lost this a long time ago and if that is all it does, i see no reason to purchase another when i can just use a wirenut or equivalent to connect the 3 wires together.
