There is no value in disconnecting the
loader lines. The supply and returns are
just open tees. The load sense line (pilot)
will have a shuttle check tee at each
junction... ie it's got a floating ball
check inside the tee.
To further the theory, each remote section
has a primary and secondary shuttle (ball
check) and a couple o-rings on each
shuttle.
When you activate a remote or loader valve
the bypass oil that is present in the
supply circuit passes over the spool and
into the load sense circuit. The pressure
rise shifts the combining/sequencing valve
simultaneously with the flow control spool
in the remote. If any of the o-rings on the
shuttles leak or the ball doesn't seal, oil
is lost to sump. Any oil that is lost
effectively limits the maximum pressure to
be developed in the circuit. The way the
shuttles work, the circuit demanding the
highest pressure will close the shuttle to
provide maximum load sense to the combining
valve. This provides pressure compensation
in the circuit. So if you have one that is
dead, the shuttle is leaking. If you dead
head another and the dead one works that
confirms the diagnosis. Likewise if you
have a leaker and you deadhead the one
providing the highest pressure on the gauge
and you get more lift from the loader...
that would tend to suggest that the
shuttles or at least the load sense circuit
for the loader is leaking.
You could also have an inlet relief on the
loader valve depending on what's
installed...
It's a complicated system.
I'm not saying that a main spool in a Rex
valve will not leak after 15k hours but I'd
be skeptical. The shuttles are known
trouble in the MP series valves and
probably to a lesser extent in these
monoblock valves.
If you have a dead or under performing
remote and all others work the first place
I'd look is the shuttles.
Rod
shuttle.
installed...
monoblock valves.
Rod
