Hello, I'm replacing the water pump seal on my UTS. I ordered the modern seal, the cover gasket, and the oil seal. I've having trouble removing the oil seal carrier (one book calls it the "accessory shaft sleeve." I removed the set screw from the side that is supposed to hold the sleeve in place.
Here's a picture of what I'm dealing with. There is some brass debris squished out over what I assume is the sleeve.
It's #28 in this illustration:
