johndeeregreg
in my last post about drill presses a while back guys were mentioning using phase converters or VFD's to open the option of 3 phase equipment into our single phase shop. some said something about you need to
up size them because you loose some power in the conversion process so my question is if i wanted to run a 2 hp 3 phase motor on a drill press what would be the best route to go and what kind of specs would i
need to have? if looking at a vfd do i need to search for a 3-4hp vfd to run a 2hp motor or do they factor the drop into the rating and a 2hp motor needs a 2hp vfd? which one is easier to set up and not have
issues with? i have talked to a couple local electricians that are generally pretty helpful and they more or less said I'm on my own to figure it out and to search google for my options.
said drill press is on an auction that ends on the 14th so not a lot of time to figure out if its a feasible option or if i should keep looking.
