caterpillar guy
So as to not mix up the other thread on welders. I weld some things with a continuous weld meaning I just change rods and go back to burning rod. I usually weld with higher amps than most will use like seldom below 145 on AC and seldom under 80amps on DC with my portable welder. I have tried to weld with less and all I ever get is sticking with the rod whether it be 7014,7018 or even 6011 or 6013 just doesn't burn well i Also don't bother with rod smaller than 1/8 inch for anything. I have found smaller rod will not fill fast enough and still burns through just as bad with thinner rod on less amperage. I also don't weld on much under an 1/8 inch thick and more in the heavier weights. I don't build much with less than 1/4 inch for strength purposes and the jobs need more iron. I also tend to over build things thickness wise.IT also doesn't break when I'm done either. I have had aluminum welding cables burn off from the ground clamp or the stinger holding them with an extra rag they were so hot. My portable never gets hot like that when welding. When I welded in the new cross members I would just go from one to the other with no stopping unless I had to move to reach them. I think it has a continuous output on it though. Would have to look for the duty cycle on the old AC buzz box. Welding rails up on the Cat tracks and roller we would just start welding and stop to change rods and rollers as we welded many passes around the rollers and idlers. Yes some jobs only take a rod or 2 to do them and it doesn't run long before stopping.
