Hello guys. After Hdonly got me started on those cheap 99 buck inverter welders, now I'm looking for one of those cheap 50 amp plasma cutters. S7 brand and others run around $276 plus/minus. Some even triple as Tig, mma/stick, and plasma cutter. However they don't have an air compressor and to get an included one then the price jumps up a few hundred bucks so not worth it for part timers like me.
Just like the inverter welder is easy to carry around, the plasma cutters are about the same size and dual voltage. However if you have to lug around a pancake compressor to with it then it isn't so portable. Read a review on one that said max input was 60 psi and his cut better at 40 psi. However it doesn't say what volume is needed.
So the question is, what kind of compressor will work with one of those? I have a few automobile tire compressors at 12v which would put out enough pressure and can probably find a small one that runs on 110v. Thanks.
