FinallyFarming
706 Model.
What would happen if you removed the steering wheel to replace the seal underneath, but then forgot to tighten the steering wheel back down so that it had 1/8inch free play if you pushed it in toward the tractor and pulled it straight back towards you?
Is it correct to assume "Nothing" would happen since the seal is retained with a brass bushing and snap ring ?
If that's the case, and the leak returned, does that point to a need to remove the pump completely and check the lower seal and possibly rebuild or replace the pump altogether?
Are kits available to rebuild the entire steering hand pump?
