jimjumper-HT
Totally lost here. 240D, running fine, parked and shut down. 5 hours later go to start and notice decomp lever is a little sticky but moves into decompression position if I bump the starter. Engine turns over, and sounds like it bogs down (like usual) as I release decompression lever so at least some compression. Won't start. Since I needed to adjust decompression lever I adjusted all the valves at the same time. Replaced fuel filter and bled fuel lines, getting fuel all the way to the injector connections. Am getting small puffs of white smoke while cranking so assume its getting fuel? Maybe a stuck rack?Since it cranks well (new battery and starter spins quickly) can I assume there aren't electrical problems? The wiring is pretty hacked from the previous owner but since its always started I haven't changed anything. I've put about 50 hours on it since I rebuilt the top end. New head gasket, rings, and rod bearings. No oil in the over flow or radiator nor water in the oil. Next step to pull the injectors and check compression?
Any ideas would be appreciated!
