Hi I hope this is the right place to put this question. I have a John Deere F935 mower and the tractor part has the engine mentioned in the heading of this post.
I replaced all three injectors with new ones as the old ones tested poorly. Engine has 3000 hrs on it. After putting the new injectors in it still runs very rough and sometimes misses on the cylinder nearest the flywheel. I'm calling it number 3.
I loosened the injector line at the injector and of course bubbles poured out. Left it loose for a while with the engine running but they didn't stop appearing. So I tightened up the nut on the injector and loosened the one on the injector pump and still had air bubbles pouring from there. They didn't stop coming even after running for probably 5-10 minutes. If I loosen the nut on either of the other injectors there are no bubbles at all.
I put a clear line on the fuel line from the filter to the injector pump to check for air getting in via the fuel inlet and no sign of bubbles once it was fully bled. So no air getting in that way.
So is it possible that one of the pumps in the injector pump can somehow leak and allow air into only one injector?
The injector pump make and model number is Yanmar 719621-51100 T606 61.
I would appreciate any advice or help I can get on this. Does it need to be rebuilt or replaced with a new injector pump or is there a seal leaking somewhere to allow air into only one injector line?
Thanks very much for any help.
