Nebraska Kirk
Doing an in frame overhaul on the engine in an international 1066 and I just discovered that most of the lifters are bad. Looking down at the cam lobes through the lifter bores and it sure looked to me like the lobes under the bad lifters were shorter than the lobes under the good lifters. So I removed the front end & engine front cover and pulled the cam. While the lobes are all smooth and shiny, measuring the height with a micrometer showed that several were worn a little and several were worn a lot, so I need a new cam as well as lifters. I also discovered the oil pump drive sleeve & rotor have badly worn splines, so I need to replace the oil pump & drive sleeve. The oil pump has the earlier 1” wide rotor, can I or should I upgrade it to the 1-1/4” wide rotor?
