(quoted from post at 13:22:45 11/24/23) Let's recap.
You have compression on each side.
You have impulse tripping at TDC on the left hand (flywheel) side.
Ok, have you visibly observed the spark plug firing when the impulse trips? If so, what color is the spark? It should be blue. Sometimes it is hard to see in the daylight, so try to find a way to shade the plug so you can observe it. If isn't a good blue spark, you have a weak spark, possibly due to many things, among them failing condenser, corroded points, corroded contacts on the cap, weak impulse spring and so on. You are using a solid metal core plug wire, right? Mags require solid metal core wires.
If all that checks out, access the inlet side of the carb and shoot in a little starting fluid while moving the left hand cylinder through the intake stroke and then run it through compression and see if it fires. We are just trying to see if it will fire, not start the engine, and it should if you have compression and spark at TDC on the compression stroke. You may need to do it a couple times. If it still doesn't fire. then obviously something is still wrong with either spark or compression. Possibly the spark plug as some have been known to spark outside of the engine but not when under compression.
I am showing 55 or so psi on each cylinder. New pistons and rings, and had the head machined. New valve springs, magneto has been recently rebuilt. Had bought new wires, just tried it with the factory wires, that were on there when it last ran. Spark is a nice blue on both sides.
Tried the ether, as I cranked, there were a couple of times when it cranked quickly, like it was going to fire, but nothing.
