Gentleman, I have a Gas'63 1010c I have
been completely restoring it for a little
over a year.
I have wired the machine exactly like the
book is showing. All the wiring and
switches are new. The problem is when I try
to start the engine it will fire up but die
as soon as I let go of the switch. Holding
the switch just a little longer in the
start position will cause it to run that
much longer. I'm using a resistorless coil
and the AT21567 key switch. The book calls
I believe for a pink wire to be plugged in
to the I terminal on key switch. That
I is not hot in run like it should be. Only on start . I
checked voltage on other sw. terminals and
found a terminal that isn't being used F
. F is hot in both positions and the
tractor starts and runs seemingly fine. I think the key switch is bad. I did purchase another one from the same dealer but still have the problem. Could it be a bad batch of switches the got ? The
only other problem is the genny is not
charging but I think I just got a bad apple
from the parts house. New one on the way. I
know it's a lot but would greatly
appreciate any input. Thanks in advance.
John
over a year.
John
