Paul 300 U
Many previous posts on my 350 purchased with one way steering. I did get it working ok after a rebuild then a previously welded shaft broke. I replaced the shaft and cannot get it to work since. Turns freely both ways with tractor off the ground and not running. With front end off the ground and engine running turns great to the right but left becomes a bit difficult. When I put the front on the ground and running , turns right "ok" but won't turn left unless I pull it very hard. I always try multiple turns and let it stay completely turned in each direction to bleed air out of system.
This system essentially functions by hydraulic pressure pushing a piston backwards or forwards based on hydraulic fluid pushing on either side of the piston. At the end of the piston rod is a race that connects to gears that move the steering left or right. Fluid to the piston is via a valve in the steering column. The steering column runs through the center of the valve which has ports. Fluid moves through the ports (Left, Right, Centered) based on up and down movement of the steering column itself. I've had it apart many times. There are no broken parts. My question today is, are there other parts of the hydraulic system that could be causing the problem. Are there other valves in the hydraulic system that could be blocked. Loader hydraulics and fast hitch hydraulics work great.
Other than working on this system I don't have much mechanical experience. With the help of the forum I've been able to make several repairs to my 300 u and my cub.
Any all suggestions welcome as I'm running out of options. My concern is that even if I decided to replace the steering box, the issue might be outside the box itself.
Thanks! Paul
Thanks! Paul
