Brokentractor71
Got around to looking at it. I posted earlier that the tractor doesn't move but you can hear the Trans shifting when you shift the lever. I heard some noise under the cab and it seems the tow is not engaging to drive the rear end. It is locked forward position. You can hear a little grinding noise. If I pull the lock lever out of position and try to push it past the locking hole moving forward it grinds harder. I shut tractor off and still will not move forward anymore. Could a pin or key be partly sheared off and the fork inside not be traveling far enough to engage? The roll pin in the arm outside the transmission looks good.
