Brokentractor71
Got around to looking at it. I posted earlier that the tractor doesn't move but you can hear the Trans shifting when you shift the lever. I heard some noise under the cab and it seems the tow is not engaging to drive the rear end. It is locked forward position. You can hear a little grinding noise. If I pull the lock lever out of position and try to push it past the locking hole moving forward it grinds harder. I shut tractor off and still will not move forward anymore. Could a pin or key be partly sheared off and the fork inside not be traveling far enough to engage? The roll pin in the arm outside the transmission looks good. Also the tractor does hold in park.
