john connell
I love my old girl having owned it for about 5 years. She's all original and runs quite well with the 292 V8 with 4 barrel carb and 5 speed hi/lo transmission. Problem is that
I can't trust her to stop without extreme effort. I'm certain the individual drum brakes all need adjusting but my biggest problem is the lack of cooperation I get from my vacuum booster. It's located beneath the seat and when it operates, my thought is that the attached slave valve sends fluid to all 4 brakes. I bled the entire system a month ago hoping for better results but instead got different, not better, results. Now my brake pedal takes about three feet of travel to the floor before feeling braking action then the second pump is only about 2 feet of travel and around the 3rd or 4th pump I often times can get her stopped that is if I don't have a big load on her. The booster does have good vacuum hose to it and sounds like air brakes releasing on a semi tractor but the action is horrible. I do have a parts truck with the same device but don't know anything about their operation. Do you? Sure would appreciate your advice. John
