I'm chasing a low compression issue. Dropped the oil pan to get at the pistons and found some pretty sizable
copper shavings (some over 1 long). Definitely not the rod bearings, they look great and are steel; I assume
the crank bearings are also steel but this is my first and only Ford tractor project ;-)
The engine is a rebuild. I had it replaced about 20 years ago when I was working full time. Shortly after
install, the tractor developed a sizeable crack in the center housing so we parked it until I retired last
year. Now that I have the time to work on it, I've replaced the center housing and got the tractor running
again. But the compression is low (90 in each cylinder) so I've pulled head, cleaned & lapped valves and going
to replace head gasket but I figured I'd inspect pistons while I had the head off ... and that's when I
discovered this copper in oil pan.
At any rate, any ideas what this copper may be from?
Thanks for any help.
