John Saeli
Years ago when we did a valve job, we'd use Prussian Blue, and if the pattern looked right, we moved to the next valve. Years ago most components were "Made In The USA" and you could trust the parts. Not today. For that reason, a modern professional shop will vacuum test every port when they are done. Strangely, even though you can get a perfect pattern, every once in a while a valve will leak and not hold vacuum. Usually turns turns out the valve face is not perfectly true, or the Guide isn't true. I wouldn't let a shop do my valves if they don't vacuum test. I sometimes hear from my customers, "My guy says you are full of $hit, been doing valves for 40 years and doesn't need a vacuum tester. Never heard of 1". OK.
I should have put this picture in my earlier post. This is what a finished CASE Power Cell "Lanova" Head should look like. All models. Intakes Flush, Exhaust Valves no deeper than 1-1/8" down.
Today, I still use Prussian Blue, but if I have a problem, I then use a paint pen, which will usually tell me what's going on.
