johnofnewhaven
Good afternoon. I'm having a problem with my 1974 Ford 5000 diesel. This is the one that I put a new head gasket on and repainted. Here's my problem. It is overheating. Now to eliminate the head gasket being the wrong one or on the wrong way I know for a fact that's not it. I also had the old radiator redone. It has all new radiator hoses and a new thermostat. This is actually the second thermostat that I put in it since I redid the head because I thought maybe the first one I got was crap but both thermostats I tested and they are opening correctly. The top radiator hose gets hot the top of the radiator gets hot but the bottom radiator stays cool and the bottom of the radiator stays cool. I am now thinking the water pump is bad. There is a slight wobble in the fan but it's only maybe 1/8 of an inch to 3/16 of an inch wobble. What are your thoughts? Before I order a new water pump and tear apart the front of the tractor again I would like your opinions. Thank you in advance.
