(quoted from post at 13:06:07 08/20/23)
(quoted from post at 18:37:51 08/08/23)
Compression test, valve clearance adjustment, full tune up (use quality parts like Standard Blue Streak or Echlin) and adjust the timing by the manual, are basic things to do.
Here's what I did:
A) I put in new points and condenser, I set the gap to .022 at its widest opening point. I've got to get the loader off before I can see the timing hole I think.
B) Compression Test: Cylinder #1: 132, #2: 128, #3: 130, #4: 131
C) Put carb back together with new gasket between the top and bottom and between the carb and the manifold intake. Fired it up and it runs nicely and I can throttle up and get the rpms to increase very nicely now, which I couldn't before - but only when it's choked at least a little.
D) Installed a new oil pressure gauge.
Results:
1) If I push the choke rod all the way in (open the air intake completely) it'll sputter and die, and
2) I suddenly got engine oil spurting out from the dipstick and leaking from the connection between the cylinder block and the torque housing on the rear end of the oil sump where it meets the torque housing.
3) No movement on the oil pressure gauge. Maybe the cable is bad from the oil filter to the gauge, or maybe I've got no oil pressure at all
***** #1. As far as I'm concerned, you don't have a "known good carburetor". Borrow one from another D-17 or WD45 that you KNOW works fine and try it. #2. Now we have engine oil leaks ??? Is the engine overfull of oil ?? that may be overfull with GASOLINE mixed with it ??? #3. Did you have oil pressure on the old gauge ?? Why did you change that out ?? If you had oil pressure before and swapped gauges and now you don't have oil pressure ?? Disconnect the oil pressure gauge line at the filter base and see if oil spews from there. If not, you have a zero oil pressure thing going on !!!
