Im having trouble keeping my case running. I bought it last fall and over the winter I changed all the fluids and filters, , adjusted the brake pedals, and greased everything. Now the weather has broke (sort of) I got it out of the garage and drove it around a little. It starts quickly with choke out and as I gradually push choke in it runs great even under mild load (4th gear on a slope). The problem is after about 5 minutes it starts to run rough and wants to stall. When I pull the choke out it starts running good again. Then it keeps getting worse until choke is out all the way out and eventually it quits running. I have adjusted the two screws on the carb. and get no improvement. I had not drained the gas tank over the winter so I drained all the gas, rinsed tank with new gas, drained carb and installed an inline filter. I filled tank with new gas and added a bottle of Seafoam. No change. I checked the compression and all 4 cylinders were about 100. I installed 4 new plugs. Nothing has helped. I dont know how to check the timing, but it runs so good at first I dont believe its an issue. Im stumped,but hope some one here can help. sorry for the long post.
