My newly acquired 895 was used with a loader for many hours but still had the original Good Year F1s with 60% or more tread remaining on the rears telling me that it wasn't a "plow mule" and the instant starting, non smoking engine with no overhaul marks on the engine verifies that. The wife of the owner sold it after he died and she had no use for it. The story from the used equipment salesman/store owner said that it was used mostly used for haying and having new front tires apparently the tread was worn off the fronts running probably 5x6 hay bales.
The steering piston, up at the front axle, has a range whereby it has moved over the years and the chrome of the cylinder is visible on both ends with the steering in a more or less straight ahead position. Turning one way it sucks up the rod till the chrome disappears at which time you can hear a slight load on the engine indicating (to me) that an over pressure valve is working and a nice tight turn can be accomplished.
In the other direction it doesn't completely hide the chrome inner shaft....about 1" of it is still visible and if you attempt to steer harder you don't hear an over pressure engine loading and my force on the steering wheel causes the wheel to turn a few degrees in that direction and stop, etc. etc. but the piston doesn't move........like on a newer Hydrostatic tractor where you can force the wheel to turn in the same manner in a steering maximum turning condition when you want to get the knob on the steering wheel to get back where you installed it in the first place.....one of the nuisances I have realized with my only hydro tractor.....unlike my older Fords that have "Power Assisted" steering and when you get to a max turn, the wheel doesn't move any additional distance and doesn't need to be reset to get the knob back where it was when centered.
The question is, do you think the cylinder up under the front axle is the culprit or the steering control operated (as part of) the steering wheel shaft assembly? The cylinder is apparently the same for most of the X95 tractors with the centered upper and lower screw attached, round attachment points above and below device and is available online for $200 and seemingly easy to replace. The tractor has a cab and if part of the steering wheel assembly I will leave it be as it is....just doesn't make as tight a turn in that direction as originally designed but its not that big of a nuisance for me to go after fixing it there.
Additional comment: Not having crawled under the tractor, I assume that there is a hydraulic hose at both ends of the cylinder and thought about disconnecting the lines one by one and testing the pressure. The service manual should have the available hydraulic pressure (about 1600 or so PSI????) and see if its the same on both ends.....if so then I'd suspect the cylinder to be at fault and if not steering wheel box....probably with what I said above, it's the steering wheel box at fault........butttt there are an awful lot of front end cylinders for sale on the www which points to a cylinder failure. Never had one apart but I would assume that the packing is a common element to both directions, in the center of a shaft so if the packing were bad it would be reflected on both ends......I would think.
Thanks for your thoughts,
Mark
Mark
