Several of the famous y tube farmers are harvesting crops now and base their October videos around that. These are mostly newer big combines and younger operators. There seems a wide variation in ground speed that these fellas follow. I have heard them say you have to load a combine to get it to thresh properly. Then it seems there is always a plug up at the feeder throat at least once in the video. Like if a combine can thresh 2800 bu/hour these fellas want to run close to that capacity. So are they saying a combine won't work properly at 1400 bu / hour because it is not fully loading the cylinder or rotor with crop material. If a combine is designed for 2800 bu / hour maximum won't this same machine thresh as good at 1400 bu /hour ? Seems like they are plugging up the combine trying to reach maximum threshing capacity when they don't need to run that fast. Do you believe a combine rotor has to be fully loaded to thresh a crop properly ?
