I recently bought an early Series 1 D17 (SN 2106). It's engine SN is high (59939-7), so I'm fairly certain it's a replacement from one of the newer models. I first noticed this because its oil filter is different than another Series 1 I have. The filter is a female threaded spin-on type, and it's an inch taller (FRAM PH8A), so the hood actually touches it when installed. Another clue is that the oil pressure gauge is pegged high when the engine is running, even at idle and with correct oil quantity (and the gauge line seeps oil).
To ensure plenty clearance from the hood, would there be a problem with installing a smaller filter with the same gasket and threads? I'm assuming I would also need to get an oil gauge from the newer series to make the oil pressure read correctly?
