I just replaced the two bearings on the sliding shaft and the two on the overdrive gear shaft. I'm having trouble getting the gears to engage properly. I've followed the instructions in the manual about
adjusting the shifting rod and everything lines up except the sliding pinion doesn't go into the overdrive gear very far, only about 1/8 inch. The book says to split the difference between 4th and the
overdrive gear but if I do that, 4th and none of the other gears line up very well. It seems like the furthest right detent on the shifting rod needs to be further over but its been like this for 76 years.
All the gears look like they have been perfectly line up, none show any signs of uneven wear. When I got the tractor the bearing that should be inside the overdrive gear was in pieces in the sump but the
gear wasn't damaged, the outer race was still in the gear. The sliding shaft was worn and I replaced it with a good used one. When I saw the sliding shaft flopping around I knew I had found my problem so I
didn't do any further investigating before disassembly so I don't know how it engaged before. Pic one shows the gear disengaged from the overdrive gear and pic two shows it engaged. When I took the pics I had the shifter shaft cheated over toward the overdrive gear a little. You can see in pic two
that there is a lot of tooth left to engage.
Am I missing something stupid? It wouldn't be the first time!
Anyone had a similar problem or have any ideas?
Gary
Gary
