I have a John Deere 1010 gas dozer that has been converted over from 6V positive ground to 12 V negative ground.
It has an alternator on it that works fine.
A electronic ignition module was installed in the distributor. The ignition Module has the p/n NV5 on it and a lot# 12AH on it.
The dozer starts up and runs good but if you touch the coil after it has been running for 15-20 minutes it is hot. 113F hot.
Is that normal for a coil with an electronic ignition module? Do coils normally run warm?
Are there specific coils that are designed to run with electronic ignition modules?
Did a search online for the mfg of the module but no success.
My son has had this dozer for a number of years and it was converted before he got it.
Thoughts, suggestions, tests I should run?
