Greetings and thank you for letting me join your community.
I recently purchased a 1964 Timberjack 205 and based on the serial number stamped on the side of the engine and the fact that it uses a simms pump, I've surmised that it came with a Ford 220 diesel engine. It runs beautifully when it starts however without any glow plugs or block heater the little engine does not enjoy starting in the cold.
While going over the machine, I noticed a block heater was installed but did not appears to work. Further testing using my multimeter confirmed that it was dead. I brought it to my local NAPA and purchased a replacement based on the model number stamped on the plug. Unfortunately to my surprise, the new block heater plug is a bit smaller than the old one. I simply cannot get it to seal up. Doesn't anyone have a part number from Zerostart or Temro that will work?
I'd also like to convert the engine oil filter to a spin on. Is there an adapter kit made for this engine?
And finally, are there any things that I should specifically look out for on these engines? It runs great as is and my ears and neighbours are grateful that I did not get a skidder with a detroit diesel.
As a side note, if anyone needs info rebuilding a gearmatic 8a winch, I'd be happy to share part numbers or any other info on it. I'm almost done completely rebuilding the surprisingly expensive little bugger.
cheers
EDIT
I found this thread:
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=720001
It identifies a temro 3100087 block heater as being compatible with a 1963 Ford 4000 tractor. However that tractor has the 172ci gas or diesel engine. Do the 172ci and 220ci engines use the same block?
This post was edited by tj205 on 12/01/2023 at 04:12 am.
cheers
EDIT
