Last summer my Farmall M had a radiator tank leak. I took the radiator to a repair shop and they fixed the leak. We I reinstalled the radiator and ran the tractor the water pump starting leaking where the main shaft comes out of the front. This water pump has been on for years no problem. I bought a new water pump and put it on and it started leaking in the same place. It was under warranty so they gave me another new water and put it on and shortly it started spraying coolant out the grease zerk on the side of the water pump. I just cant believe I had 3 bad water pumps? could it be the radiator is plugged partially some how from the repair of the tank building up pressure in the water pump? Any ideas on this problem would be greatly appreciated. It just seems strange that all my problems started when I had the radiator tank repaired. Thanks
