kjoelsulli
Ok guys need some help...
Bought a Super A, was working fine and then all of a sudden a stuck clutch. I tried the ideas for unsticking and finally decided to break apart.
First time: change the clutch, pilot bearing, throw out bearing. we noticed 50 plus years of dirt in the bell hosing cleaned this up.
--> Still same issue the Clutch would grind.
adjust clutch pedal travel and Clutch pressure plate arms.
second time: Based on talking to friends that have farmalls, they mentioned to check clutch fork, it was and issue, it was replaced.
==> Still clutch grinds when trying to shift into gear.
Third time breaking apart:
Inspected everything on the new clutch, throwout bearing etc. noticed on back end of the bell housing where it mounts to tranny looked clogged up. We already had planned to break apart to replace the leaking tranny seal.
So broke apart by tranny, noticed clutch pedal rod area was still very clogged with dirt (leaking oil from tranny). So we took bell housing and pressure washed to get all the old dirt out. Can now see original paint on inside of housing type of clean.
Replaced gaskets and seals on tranny, put tractor back together and still have issue with the clutch not disengaging. only thing not replaced is the flywheel.
We paid very close attention to how the bell housing went back on to engine block to make sure nothing was bound up. it slid right together fairly easily.
Any ideas or thoughts?
Could the clutch I have be out of spec? could the fly wheel be the issue? The tractor starts first attempt, no spoke so really want to resolve this issue.
