TractorDan530
Hey Fellas. First tractor here and it was in the right price range so I picked it up. Looks like every nut and bolt has been farmerized and stripped down but I'm looking to give it a good once-over and get it running for the couple projects I have around the property.
I was told it's a 1961 Case 530. Typical placard on the dash is gone so I'm left guessing with what's equipped.. here's what I've found.
#31 loader.
G159 gas engine
Dual Range on the lower right.
Shuttle on the left.
Autolite dashboard (wrecked)
Single cylinder power steering
No PTO
Eagle Hitch - disabled by lack of cylinder
I'll post some pictures to help identify what I'm talking about. Today's project was removing the filled sediment bowl, filter, and ultrasonic the carb. Tomorrow's project is to determine what's going on with the power steering.
Tractor has gear-driven power steering system with lines going to a single cylinder mounted to front axle. No visible leaks and system is full - checked reservoir. Steering has typical slop but the wheels WILL NOT TURN unless you FIGHT with the wheel or use the loader to lift the front axle off the ground and then still struggle to turn the wheel.
I pulled the fill plug on the gearbox in front of radiator and it's bone dry... filled it with gear lube but haven't tested whether that would make a significant difference anyway. Seems like that power steering system isn't doing anything. Anyone fought this bear before and able to give me a leg up in the battle? Not a professional by any stretch but I'm good at being poor.
#31 loader.
G159 gas engine
No PTO
