I have three fluorescent yard lights at the farm. It seems the bulbs have a rather short life. When I went to get a replacement at Home Depot, they didn't have any and the clerk referred me to a LED replacement. On the package it said in large print replaces large base fluorescents and sodium vapor. It came with a screw-on large base adaptor. I thought how this could be a bulb that works with both regular 120 volts and output from a ballast. I thought well with modern electronic wizardry they must have it figured out. Got up on a ladder and replaced the burned-out fluorescent with the new LED put my hat on the dawn to dusk eye and flipped the switch. Nothing, I then examined the package and noticed a warning printed near the bottom in very small print not for use with ballasted fixtures. I fished the directions from the package, and it contained instruction on how to remove and bypass the ballast. So, I took the fixture down and removed the ballast. Before I tried the LED bulb on the bypassed fixture I tried in a trouble light, it didn't work. I had purchased two bulbs, so I tried the second and it worked fine. Exposing the LED designed for 120 volts to the ballasted voltage destroys the LED. Back up the ladder with the spare LED to install the bulb and now all is well. So, I feel pretty stupid, but I hope you can learn from my ignorance.
