toolgarage
All,
I have a PTO clutch that is in need of replacement on my 5600. When I look at the Ford service manual, it states to crack the tractor between the front and rear transmissions to access the PTO clutch. When I look online there are references to accessing/replacing the PTO clutch by removing the hydraulic lift cover. Can anyone give guidance on which way to go to replace the PTO clutch on a 5600 with dual power, single speed 540RPM PTO? I would much prefer to go in via the lift cover, but if I have to split the tractor as the only option, then so be it.
Thanks!
Thanks!
