Hi, I recently bought a 1958 Case 420B loader/backhoe. The engine runs well and the machine is capable of doing work, but I'd like to repair two things that aren't working: the brakes and the power steering. As for the power steering, I have the belt to install. One hose had a cut in it, so I need to replace that and probably should replace the other two hoses as well. I see it takes ATF. Does it matter what kind? I'm sure I've got some ATF-4 around. Anything I should be cautious about before replacing the belt and hose, filling up the reservoir and seeing if the power steering works?
As for the brakes, I'm not certain where to start yet. I've been doing a little searching haven't found anyone doing brakes on this model.
