I have slowly been fixing the leaks in my work tractor but it unfortunately developed a new, worsening one. The power steering control valve that the steering wheel/shaft goes through is leaking from the plug. It appears that the plug was designed to have a hole it it to allow the leaking fluid to weep. Once my hydro fluid gets hot it becomes a fast drip. I'm not sure if its because the fluid gets thinner as it heats up or that its not venting properly from somewhere else. The plug that leaks is between the power steering hard lines on that control body.
