ReynoldsFarming6610
I have a 1994 ford 6610 that is leaking steering fluid somewhere. I don’t see any coming from around the reservoir seal or any noticeable leaking around the steering box. I can fill the fluid reservoir up to the fill cap and drive for about 15 minutes and the fluid level has dropped about 1/4 of the way down.
I do have a small drip under the tractor weep hole with cotter pin. But drips maybe 6-7 times after tractor is off and then stops.
I’m not sure where this fluid is going. Maybe a seal in the actual power steering pump and going into crank case
I also don’t see any noticeable leaks from the steering cylinder on front of tractor
