1349
- Location
- NW Oklahoma
1976 JD 4430 Syncro....working fine, just changed screen and filter, moving hay with it 158 loader, just stopped moving. I pushed in the clutch to go to Rev....I felt something inside just pop. Now tractor will not move in any gear, with the clutch pedal out, you can shift thru the gears regularly, no grind etc. It just feels like the clutch pedal is down, disengaged inside. Steering, brakes, PTO, 3 point , remotes (loader) etc all work normal. Just no move. It will not even try, I have a set of guages and IT manual. but the hyd test is pretty vague, and everything else working seems like a waste testing everything. I have searched the archhives, one post is similar but he says they changed the clutch valve? and had a very worn tractor after that fix....etc etc. This is a 10,000 hr tractor but well maintained and kept up. I had the main hyd pump rebuilt approx 250 hours ago. no leaks etc. Need advice where to start here, THANKS
