Joe Stewart
This 4430 has been sitting in the seller's yard for about the last 15 years without being started. The price was right so I bought it. The water pump was frozen, so I removed it for rebuild. I spun the motor by putting a pry bar on the ring gear. The turbo spins by hand. I have not attempted to start it yet. Today I took a pressure washer and sprayed into the thermostat manifold (upper red arrow). I expected the water to travel through the engine and exit at the port where the water pump bolts on (the lower red arrow).
I was never able to get any water to come out of the bottom (lower arrow).
Can anyone explain to me why I cannot get water to pass through this motor? It seems like there is an internal blockage. I do not want to re-assemble everything until I have solved this issue. Thanks
